Please refer to the pdf attached.
I would like to know how to edit the "bottom of borehole XX 20 feet" entity in GINT. I am using the "GENERAL BH / TP / WELL" report or template. I have been opening all the columns but haven't seen yet where this entity is at.
Please let me know.
PDF
Look for the "Boundary Text" tab in the "Material Description" column properties, there should be an expression <<User System Data.Termination Note>> in the "text Below Last Line" field. You will need to edit that in User System Data under Data Design
