Hi! I would like to edit the header. I want to change some of the text that says "ft" to say "m". Any advice?
thanks!
Kerrie, editing the header will happen from the Report Design>Blocks>select the name of the header from the yellow drop down list. Then open the entity which you want to edit. These entities in the header are text properties where the place card holder will be in the Main tab and the actual text expression will be in the Associated text tab.
Assuming you are using gINT Standard data templates, the change in Ground elevation entity, will be pretty straight forward to do from the Associated text tab, where you can change from ft to m.
However for At the end of drilling is a combination of multiple User system data expressions. Under Data Design>User System data>Water Depth / Elev is where it says 'ft'. which you want to change to m.
You can learn more about blocks in this tutorial.
Answer Verified By: Kerrie Berg
Thank you, this was really helpful and so was the Log Report Design PDF.
