Good day,
I've installed gINT Professiional Plus 10.01 (trial) and ArcGIS for Toolbar. The following errors messages appeard when trying to use the button "Import gINT Project""Object variable or With block variable not set"Unable to initialize Licensing""Subscript out of range"Runt-time error 9 , Runt time error 5."
GINT itself works. ArcGIS is version 10.8.1I will be grateful for your help
The version of gINT you have mentioned is too old for the arcgis.
User must have full admin rights on ArcGIS. There are settings that can be configured in ArcGIS that do not allow a user to use Addins. The gINT toolbar is an addin for ArcGIS. Have the user try running ArcGIS as administrator.
Each version of ArcGIS may have it's own directory structure. So the config file instructions may need to be put in a different folder depending on the version.
You will need gINT 10.02.00.04
We have only tested on ArcGIS version 10.1 other versions like 10.4 10.8 etc of ArcGIS have not been tested but we have users that are able to work with them.
