I have recent BH data and Historic data and I would like to represent the Point ID with different colours e.g. red for recent green for historic.
I am able to do this in the Site Maps under SM report properties>Data Rep>Data Marker Color Exp (output below and expression used)
However, how do I represent this on my fence site map? I have also noticed there is no option for this in the site map tab too.
You can't change the color, but you can change the data marker. Its not perfectly what you wanted, but it will differentiate the points on your fence site map, and you can use the same method on your site map.
Hi Judy, thanks, I had already done this, but I thought the colours helped make this stand out better.
Very true. I fought with it several years ago trying to do the same thing and had to settle for the different data markers.
