Hi. I'm trying to figure out why I'm getting this message on my gint collector when I try to create a new plan.
gINT Collector – Create New Drilling Plan Error: “Library settings have not been copied to the drilling plan dur to an error with the service. Drilling plan can be used….”
In this case, the only setting that has not been copied is this one, and it will simply not prevent sycn operation even if there’s missing required properties, it means this toggle setting is simply ignored:
Block synchronization on the gINT Collector app when required properties are missing.
When turned on, the gINT Collector user will not be allowed to sync if one of the required properties is missing in one of the forms. A dialog will inform the user about missing properties.
When off (default), the user is notified that some required properties are missing, however, sync is not blocked. Handling those cases when importing the data back into gINT Project then becomes the responsibility of the project administrator.
This setting applies to every form that is part of the Library iModel.
