Hi I am fairly new to gINT, I ahve been using it for a week now so I have a basic understanding of the software and I understand how to enter and pace boreholes and surface lines onto the fence diagram, Howver I am wondering how do you add the offset position of a borehole into the data to show on the cross section/fence diagram? I understand this can easily be done on CAD but I was wondering if there was a method on gINT
Vikrant
The Distance Axis Offset and Vertical Axis Offset properties move (horizontally) and compress (vertically), respectively, the fence posts so that they do not touch the frame border. This can be accessed by clicking the Fence properties icon. Go to report design, select Fences option and click on the properties icon (hand holding paper) that is to left of the yellow drop down.
You can read about this in the gINT Help>Distance-Vertical Axis Offset (report property)
Hi sorry, I meant on how to add a offset distance from the Test Pit locations I have done, however I figured out how to do it through a line of code which was supplied on another page
If you have Northing and Easting coordinates as well as an elevation for your boreholes and you're using a baseline or alignment, then gINT automatically determines the station and offset and plots the borehole at the correct location and elevation. If you want gINT to show the station and offset with text, then you need to add a text entity on your fence diagram and use the following functions:
For stationing, use <<AlignmentStationFromCoor(<<FenceBLAlignment>>,<<POINT.North>>,<<POINT.East>>)>> and add formatting. There's also the <<StationConv()>> function as well.
For offset, use <<AlignmentOffsetFromCoor(<<FenceBLAlignment>>,<<POINT.North>>,<<POINT.East>>)>> to get the offset. This will give you a positive number for offsets right of the alignment and negative numbers for offsets left of the alignment. I have formatted mine to always give a positive number and add the words "left" or "right" depending on the case.
Note, these functions only work if you have the Alignments support enabled.
