I have multiple boreholes (20) in one gINT file. I want to combine non-core log, core log, well log, and core photos for each individual boreholes. How can I do this by writing a script ?
Hi Aruna, this webinar recording will give you some insight into how gINT Scripts can be used to do this.
Thanks Jesse. I watched your video. I was wondering how we can merge core photos to same log using script ? Also, is there any way to change EOH remarks within script ?
Hi Aruna,
If you are asking how to generate the core photo report from the script... you would need to add a section into the overall script to output the core photo - ie after the section of the script to output the logs.
If you are wondering how to import the core photos into gINT... as you are probably aware, you would typically only include a path to the photo file location in gINT (rather than importing the actual files). If you wanted to automate the import of a batch of photos, you could do so with gINT Rules using some logic based off file naming or folder organization to link them to the correct records in your gINT database. I'm not sure you could do it just with gINT Scripts.
Typically EOH remarks would be stored directly in the database or be generated by an expression in your report. If for some reason, you wanted to pass them in through a gINT Script, you could have a Report Variable for your EOH remarks and update that in the Script. There are examples in gINT Help of how you can use Report Variables in gINT Scripts.
Thanks Jesse. I wanted always have EOH remarks below depth in my well log whereas EOH would be either above or below depth in my cored and non-cored log. As I am trying to generate all logs using one script, I wanted to change EOH below depth if EOH is marked as "above depth" in point tab while running script.
I am not very good at Report Variables. Do you have an example script which gINT can change EOH remarks ?
Thanks again
Hi Aruna
If you are who I think you are, your company has the Datgel Output Tool www.datgel.com/datgel-output-tool, it is designed to do this.
You can contact support(at)datgel.com for technical support.
regards
Phil
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
