how to change field properties with rules
I'm trying to make a rule that will change field properties (required, read only) and can't figure out how the correct usage. Any pointers?
it will eventually be part of if statements but for now...
I get ActiveX automation object var is Nothing
Sub main
Dim depth As Field
depth.Required = True
End Sub
Parents Reply Children
