gINT will not open on my machine. I get a pop up "gINT Startup Error" that says "Error in Startup.StartProgram (-2147221164)Class not registered Line number 1
Then I get "Run-time error '429'; class not registered.
Help!
Hi Meredith,
We see that you have created a Service Request and will correspond to you via the service request ticket you submitted.
For the larger group here are some standard troubleshooting for general Startup issues.
Here are the standard troubleshooting for errors on opening
Download CONNECTION Client for Bentley Users
Goto C:\Users\”your user name”\AppData\Local\Bentley\gINTCLRename the setup.gsh file to oldsetup.gshTry reopening the program. Set the defaults
I am having the same issue with a user who also has OpenRoads installed. If our IT group gets OpenRoads working, gINT will not open. if they get gINT working, OpenRoads will not open. same error message as Meredith. Followed instructions below without success. Can you update if you have any additional solutions?
Hey. I never saw the response from Kirk below (until I got an email) RE: Judy Smiths comment. I fixed it (I think) by updating Connect, and removing, then reinstalling the latest version of gINT. Seems to be working so far. Good luck!
We tried that as well, with no luck, but i will double check versions. Thanks!
