Edit Line Thickness in Report Design >> Fences
HELPPPP!!! How can I edit thickness of this line in Report Design >> Fences?
I can only change the line thickness of the horizontal line:
Tons of thanks!
  • The vertical line would normally by a "vertical line to depth entity".  The properties box you included is a lines vs depth entity intended for generating horizontal lines only (as displayed in the top of the properties box).  You may have selected the wrong entity to edit. If you select the correct entity it should give an option to select the thickness and color of the vertical line and should display "vertical line to depth" in the top of the properties box.
  • I selected the 'vertical line to depth' entity and input the line thickness I would like (0.07) but still cannot show the change in the exported CAD:
  • Did you select the vertical line entity that was already in your fence report, or did you create a new one? The screen shot of your vertical line vs. depth entity dialogue box doesn't have top or bottom depth expressions, so it shouldn't output anything (unless you added those later). The screen shot of your cadd output shows a vertical line that appears to match the top and bottom depth of a strata. If that entity is already in your report, you need to select that and edit the line thickness there.
  • I suspect there actually may be multiple entities already in the report that are generating vertical lines in the same location. They can be generated with range lines of a text entity, left or right boundary lines, descrete graphics, etc.. I have found it useful to set each potential generator to a contrasting color and extra thick in turn to see what it generates  then eliminating undesirable sources. You can also confirm by deleting the line selected in you cad screen shot and refreshing the view. I suspect another line will appear beneath the first.
  • Also, as William Ladd indicated above, make sure you are selecting and opening the existing entities in the report (double click on the vertical line in the report design window) rather than opening a new entity from the fence menu.
Reply Children
