HELPPPP!!! How can I edit thickness of this line in Report Design >> Fences?
I can only change the line thickness of the horizontal line:
Tons of thanks!
Thanks for your reply. Do you mean this:
I would like to do the way round - make the line thinner. Do you mean this? Any idea what to input for 'column width expression'?
I see, if you want it thinner I don't think this is the way to go. I was thinking you wanted a thick "bar" to represent your boring on a fence diagram. From your response to szang, if you want this output as a line to autocadd you are better off using the vertical line.
Did you select the vertical line entity that was already in your fence report, or did you create a new one? The screen shot of your vertical line vs. depth entity dialogue box doesn't have top or bottom depth expressions, so it shouldn't output anything (unless you added those later). The screen shot of your cadd output shows a vertical line that appears to match the top and bottom depth of a strata. If that entity is already in your report, you need to select that and edit the line thickness there.
I suspect there actually may be multiple entities already in the report that are generating vertical lines in the same location. They can be generated with range lines of a text entity, left or right boundary lines, descrete graphics, etc.. I have found it useful to set each potential generator to a contrasting color and extra thick in turn to see what it generates then eliminating undesirable sources. You can also confirm by deleting the line selected in you cad screen shot and refreshing the view. I suspect another line will appear beneath the first.
Also, as William Ladd indicated above, make sure you are selecting and opening the existing entities in the report (double click on the vertical line in the report design window) rather than opening a new entity from the fence menu.
