export AGS from gINT giving errors
I am trying to export an AGS file from a gINT project which contains lab testing data. The gINT project template is gint std ags 4_0_4.gdt and I am using the ags 4_0_4 correspondence file. However, when I export, only the HORN and LOCA tables export, and I get the following errors:
"ERROR: Line 1 - group 'HORN' is not an AGS group. (Rule 5).
ERROR: Line 2 - Group 'HORN' does not have 'HOLE_ID' as the first field (Rule 6a)
ERROR: Line 6 - group 'LOCA' is not an AGS group. (Rule 5).
ERROR: Line 7 - Group 'LOCA' does not have 'HOLE_ID' as the first field (Rule 6a)"
Any suggestions on how to export the lab results to AGS?
Thank you
Parents Reply Children
