I am looking for the best way to discard records while producing an AGS file. For example, I'd like the correspondence file to check a boolean field like "DoNotPresentInAGS" but I don't want to put the condition on each field of the table... I can see that having the condition only on a key field such as PointID doesn't work unfortunately.
Any help would be appreciated!
<<ExportKey>> Data item helps you do this.
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
Answer Verified By: jerome garnon
Fantastic, Phil!
exactly what I was looking for.
Thanks a lot
Jerome
