How to change the PP units?
I was wondering where to change the PP units. I noticed that in one page it is in kg/cm2, however in the report page it is in TSF.
Refer to the file attached
.PDF
  • Hi William,
    Thanks for your input.
    I checked both the column header label in the Column tab and the text expression in the main tab but did not see anything related to PP units. See file attached.
    I also check the "User System Data" and did not see anything related to PP in the yellow tab. Please refer to the file attached as well.
    Please let me know your thoughts. ThanPDFks.
  • So as far as I understand, you are wanting to change the tsf units in the report.  This will be in the Component description table in the data design.  See this  screenshot.
  • I do not have gint available to me at the moment so I xant give you detailed instructions and will have to do this from memory.  I can do better thus weekend.
    Based on the pdf file above you are on the right track and very close. The pot us printed from the component description function that you showed on the last page. It references a component description table called TESTS. You will have to edit that table to change how the units display in the body of the report. Can't quite remember where to edit that table but it us probably under the data structure tab under library tables then select the table. Also may be a separate tab for component description tables....cant remember. Once in the TESTS table you need to find the line that prints PP. The units are probably in the suffix column or print after column. Again cant remember what it is called. I can provide better details Saturday or Sunday when I get back to my computer.
  • Thanks Aparna, I worked!.
    Another question related to the same subject (or let me know if you prefer to create a new topic):
    Whenever I have no PP values (blank cell), but I do have MC values, in the logs, GINT DOES NOT show the test column. See file attached. I called it case 1.
    If I enter a dash (-) in the PP cell, GINT shows the MC values and the PP value as a dash line ( PP = - kg/cm2). I called case 2.
    Is there way to make gint work indepedent2- PP.pdfly between MC and PP values?.
    For example, if  there is no PP value I will leave the cell blank BUT I do want the MC value shown in the logs.
