I have a gINT command script that I use to export the results of several reports at one time. I use the FolderGeneral parameter at the being of my script to input the path to my project folder where I want the reports saved.
That parameter opens a dialog similar to Windows Explorer, only gives me the option to specify a location on my local drives, not my agency's ProjectWise environment. Is there a way to get it to point to my agency's ProjectWise environment? Like it works if I am saving the results of any one report from the output tab.
gINT 10.03.00.09
ProjectWise 10.00.03.453
Brian L.
