I want the point id to show "BORING ID" if there is no well present, if there is a well present, I want the point id to show "BORING/WELL ID". Not entirely sure how to code that.
Got it figured out.
Not sure what you settled on, but the HasData function is a good option for that case, where you check to see if a field in a well installation table is populated, if so use the Boring/well ID, if not use Boring ID
Answer Verified By: Corey MacIsaac
That is exactly what I did!
