Continuously arriving at "File already exists" error when attempting to change library. The library I would like to use is located on my company server. I attempted to copy the library into a folder on my local desktop but will reach same error several times. There is one library that will allow the program to open but then when I attempt to change libraries the same thing happens.
See screenshot below example of errors...
It may not be the problem, but I would suggest repairing or re-installing the Microsoft Access Database Engine. I have had some strange errors that were caused by that issue
You are absolutely correct. I had 2 versions of Microsoft Access downloaded on my computer, 32 bit and 64 bit.
I simply uninstalled these 2 versions and re-downloaded the 32 bit version and the problem resolved itself. Thank you.
