We are trying to export an AGS file (4.0.4) from a gINT project file that was created using gINT template gint std ags 4_0_4.gdt, we are also using the ags 4_0_4 correspondence file. However, when we export, it still shows AGS version 3 as per gINT AGS Checker along with huge number of errors through we are 100% sure the gINT database is correct.
Furthermore, we make sure the information mentioned in "File Transmission" TRAN_AGS are correct and not blank as shown below:
Any suggestions please on how to avoid getting AGS 3 version by checker or can you assist to figure out the issue with exporting to AGS data file 4.0.4?
Thanks in advance.
Arafat, make sure you have selected gINT std AGS 4_0 library when you run the export AGS. See the screenshot which shows the correct AGS version in the checker.
