How to combine multiple gint files to one
I have 100 gINT files and each has one borehole logging data. I want to combine them into one Master gINT file. Can I use a script for combining these bore logs or is there any quicker way to do this ?
Thank you
  • You can do a batch import of files which is found under Input>Import Export>Batch Import.  Batch import is designed to do multiple project import at once.
    The batch import from project files can be found in INPUT..Then goto File Menu ..import export...batch import from databases
Reply
