I have multiple BHs in one gINT file and I need to generate core photo logs for each BH separately ? How can I do that ? There is a way to generate individual reports for non-cored and cored logs as shown below
But I couldn't find a way to do the same way to generate core photo logs.
Thank you
If you are using the PDF output, you can separate the boreholes by selecting the option for each borehole to a separate file. However, the property of File name expression was there in older versions of gINT. We do not have that property in the newer versions. This property allows you to specify the name of each file that will be created when you export to a PDF. You can read about this property in the Help section of gINT under Help>Content> File name expression
This option appears to be only available for logs. If your photo log template uses a graphic text document or other log type it will not be available. For this reason, my photo log template uses a log type and plots 2 photos per page. I do have another template that uses a graphic text document type and it is not available for that template (though you can still have it generate separate files by ticking the box). Not sure about the version issue mentioned by Aparna but it is available in my version and one would guess it is available in your version if you showed a screen shot of it. Developing a picture log using a standard log type is not too hard and I think there is an example somewhere on this site that I used to develop mine.
