has anybody already have issues with bar chart not working in fences, or is it me doing something silly?
Thank you
Hi Jerome,
Nothing is being reported as a problem showing bar charts on fences. I just threw a random assortment of bar charts on a fence and the output as expected. Disregard the messy fence , but bar charts are showing up ok
If they are not showing at all verify you don't have any output conditions set in the configuration tab that aren't be met or don't apply
If you want me to look at your files just click on my name and send me your contact details and I can send you a secure location to upload for me to look at
Is there guidance somewhere on how to set this up?
Thank you.
Hi Brian. All of the bar chart material would be in the gINT Help menu inside the program. There is nothing specific to bar charts on fences. The general properties would be the same. You can't use column entities on fences, that is not unique to bar charts all column entities are only for logs. So u would use just bar chart vs depth entities and text entities for headers and labels. If you have something specific in mind describe what you want to do (send example) and I will advise.
Hi Kirk, Could you share your files (library & data file) from your example above? Then we would all have a working example to study/dissect to learn from and use for a template.
See my response to the post here:
https://communities.bentley.com/products/geotechnical1/f/geotechnical-forum/226324/report-design#699284
For additional guidance and links to tutorials.
I have posted multiple examples of bar chart entities in fences in this forum and will try to find them. I will add links here when I can do a thorough search.
