I am running into an issue were on the second page of my logs I have fields printing over other fields. I think the issue is coming from the title block of my logs being removed after page 1 and my data columns moving up to adjust for the new free space at the top of the page but the text elements I have are not adjusting in the same way causing the overlapping issue. I have tried to include the same header in page 1 to all the pages of the log but am running into the same issue. I did not create this report template so I am not sure how to stop the data columns from moving up or how to make the text elements adjust properly from page 2 on. I have tried lumping all of the data together as a block but I it did not work. Any help at all would be great thank you.
^This is the correct header on the first page
^This is the incorrect header that appears on the following pages. As you can see certain elements have been shifted. I need this header to stay exactly the same for every page.
Hi Tanner,
There could be a few possibilities, but the most likely is that you have the body height different on pg 2 than pg 1 set on report properties.goto report design ...pick report ..pick properties button..report structure tab..set body heights pg 2 should match pg1
Answer Verified By: Tanner Avery
This fixed my issue thank you.
