Random Line showing in the RQD column in the logs
Please refer to the file attached. I was wondering if anyone knows what is the reason of that random line showing on the RQD / REC column?. Please let me know. Random Line in the RQD column.pdf
  • Hard to say as the data you provided appears to be from a different boring than the output example. However, given that the line apears consistantly about  0.12 meters below the top of the sample and the sample length is 1.5 meters, I would guess that somewhere in the entity you have an expression that references your sample length and tries to convert from inches to feet (1.5/12 = 0.12). Could be in the bottom depth expression, the range lines, callouts, or a separate line vs depth entity (or someplace weird that I cant think of at the moment). This is common when a template has been converted from one system of assumed units to another.
Reply
