How to show the depth every meter instead of every 2.5 m in the logs?
I would like to show in the logs the depths every meter instead of every 2.5 m. Anyone knows how to adjust this in GINT?
see attached,assigning different depth values.pdf
  • Hi Pelelo,
    A very quick simple solution.
    If the scale change should only affect this one report.
    Option 1
    Goto report design..double click on the scale column to open it properties.
    Then goto  Scale numbers tab set increment to 1. Then goto Scale ticks tab change set 1 to 1 remove what is in set 2 unless you want an intermediary tick leave what is in set 2
    You will get something like this
    Option 2
    If you are using a standard file set there are probably some user system data items in there already
     Goto Data Design…User System Data and pick  log scale  inc major  and change appropriately There is another one for  log scale inc minor
    This will affect every report in your library vs option 1 which will only affect the one report you edit.
    CAUTION !!!
     If you choose to edit the User System Data Items this will modify every report in the library referencing that User System Data Item to the new equation.
    There are other options like creating new user system data items or exploding the reference user system data items and then editing them for this report and then using them in the scale increment properties, but I won't go into that in this discussion
    If option 1 doesn't work and you need something more regarding option 2 or other options let us know
