Bar Chart
Hi. I am trying to create a bar chart using RQD data (depth (ft bgs), bottom (ft bgs), and RQD) but I am not able to get the chart to produce properly. Does anyone have a example I could follow?
  • Hi John,
    One of our free reports sets has a bar chart for RQD and Recovery
    You can use it as an example for your report. You would need to modify the expressions to match your database and the way you enter data etc.. (IE you may need to calc the Sample bottom if you input sample length in inches vs feet, if your RQD is not entered as a straight percentage you may need to Calculate that and so on)
    It is log_a_gwgn02
    It can be downloaded here
    under the section Geotechnical Log with Well (U.S.)
    Follow text file instructions on how to use it.
    Log reports - usually boring logs - can be designed to present environmental, geotechnical, or a mixture of other kinds of data. See Using gINT Downloaded Examples for instructions. ENVIRONMENTAL LOGS…
Reply
  • Hi John,
    It is log_a_gwgn02
