Hi there,
I am using the Datgel CPT Tool gINT Add-In to create CPT reports. During sampling some depth intervals were missed (eg. measurements jump from 1.55 m to 1.75 m). This is causing gaps in the reports where data was not measured. Is there a way that I can smooth over this data so that there are no gaps in my report?
Many thanks in advance.
There is discussion on how to incorporate smoothing into output of graphs in the following post
https://communities.bentley.com/products/geotechnical1/f/geotechnical-forum/224962/gamma-log-clean-up-for-report#693610
However, It sounds like you are really not looking to smooth the data but to interpolate across gaps which is a very different request. In that case you need to clarify what the data looks like and what you are expecting. Datagel may be able to help you directly with this
Hi Liadh
The gap between readings that will trigger the line not to show is defined here: <<User System Data.DG CPT Plot Max Depth Gap>>
To edit it, select DATA DESIGN | User System Data | DG CPT Plot Max Depth Gap
You will get a straight line between points. I don't think having a longer straight line than the existing expression provides for, e.g. 50 mm, is going to look right. I think it is fine to have gaps in your data if that is the reality.
regards
Phil
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
