Borehole Log Template with Sieve Analysis included
I recently completed a ton of drilling where we collected samples for sieve analysis at different intervals. Does anyone have a template that displays the borehole information including geology/lithology and description and ALSO a chart/ graph that displays the sieve data from the lab? I want to have the borehole info on the left and the Sieve data on the right side of the sheet.
I looked through the files on here and had trouble finding one. I attempted to create one but I'll be honest, gINT has a steep learning curve for newbies when it comes to building templates and linking tables/data.
ANY help would be appreciated.
  • There are several things you need to clarify as this is a very general request.
    1. How is your Sieve data entered? Table/field names
    2. How do you want the output to look? Do you want a complete GSD curve for each sample? Are specific sieves representing divisions between fines sand and gravel sufficient? which sieves?
    3. If specific sieves do you always have data for those sieves (even if it is 100%) or will you have to interpolate between sieve sizes.
    4. What log template are you starting from? If you are using a smart log that varies column position and size based on available data it can get very complicated to modify.
    The very simplest way to display Sieve data is a simple text entity that outputs the results of specific sieves. An example of this is shown on the left hand side of the picture below.  You can have it do the math and enhance this to output %fines, %sand, % gravel. Etc.
    If you want a graphical representation you can use a bar chart to show the % of specific ranges of sieves as shown on the right hand side of the picture below.
    Another way to represent it graphically is to plot specific sieves as points vs  depth.
    If you want complete GSD curves for each sample you may have to follow Phil Wade's suggestion above.
    Again lots of possibilities but the approach depends on how your data is structured and what you want.
    Note the above is just an example. The data is just made up and does not make sense.
Reply
