how to stop Rounding of SPT refusal, and Rounding of borehole terminated at depth?
new to gINT and tow of the things that I need to fix for my company is rounding number. Specifically rounding of SPT refusal and terminated at depth.
I don't want these numbers to round. I search the forms and found it should be on these two coding pages but don't know what to type. and I'm worried I will mess something up.
Can some one message my the test I am supposed to enter. or if there's a easier way?
  • Go to Output and pick the Log you want, then (on the same row of buttons as Input and Output) click Report Design and it should take you to the same Log. If it's a Graph or other kind of report then you'll have to click the Graph tab or such. If you don't see Report Design as an option then either you have gINT Logs but not gINT Professional or the person doing your job before you locked everyone out of the design tabs to keep them from breaking stuff. Check back if that is so. If you get to Report Design then you should see something like this:
    Use some of the zoom options (lower right of screen in my picture, may be different on yours) to get in closer on the blips in the column which you are interested in. Like so:
    Double click on the one you want and you should see this window:
    You are interested in Text Expression. You can (but don't have to) click on the three dot button to the right of Text Expression to get more room to work:
    This is where your log formatting happens. I don't know what will happen if you remove the format statement altogether, but make a note if you do because the problem that may or may not cause can hit you next year and slip your mind about what caused it.
    It's a good idea to make a copy of the report under a new name and test your edits there. I think you already did that but I can't tell for sure.
  • I see what your saying about text expression, BUT when I try it still doesn't work. tried a couple of ways now. I pretty sure this is the right box because in boundary text it says termination.
    Watch I'm going to figure all this out and my boss is going to switch us to Bentley open ground right after. lol
  • For my logs, I click on the word *description* and when the window comes up go to Boundary Text. That's where I change the Text Below Last Line
    I would change "<<RoundTo(<<stuff>>,0.1)>>" to just "<<stuff>>" to get rid of the rounding. Make sure you get rid of the ",0.1)>>" as well as the "<<RoundTo("
Reply Children
