new to gINT and tow of the things that I need to fix for my company is rounding number. Specifically rounding of SPT refusal and terminated at depth.
I don't want these numbers to round. I search the forms and found it should be on these two coding pages but don't know what to type. and I'm worried I will mess something up.
Can some one message my the test I am supposed to enter. or if there's a easier way?
Line 20 in the usersystem data screen shot for penetration sets the format on the penetration. It is currently set to 0.0 so it should be reporting 1 decimal place (ie 5.2 on your example) It is not, so your log form is either not using this user system variable or it is being further formatted at the log level. As others have explained, you need to go into report design for the log in question, find the entity that is reporting the spt, double click on the entity to open the properties, in the main tab will be a property for data expression. that expression is the first place to start but note that you may have to change it in more than one place
The user system data for the end note just generates the text portion of the note. The number and format is generated at the log report level. Again, go into report design, double click on the column that has the end note to open the entity properties. The end note is in the boundary line text tab. Don't have gint available to me right now so can't tell you the property name but it should be fairly obvious.
Good news after much guess and check, I was able to get SPT to stop rounding. not sure even how it worked TBH but happy it did.
I still not have much luck with stopping termination TD from rounding. BUT it looks like there are some new info from kind people on my post so ill see what I can try next. thank you everyone :)
I see what your saying about text expression, BUT when I try it still doesn't work. tried a couple of ways now. I pretty sure this is the right box because in boundary text it says termination.
Watch I'm going to figure all this out and my boss is going to switch us to Bentley open ground right after. lol
For my logs, I click on the word *description* and when the window comes up go to Boundary Text. That's where I change the Text Below Last Line
I would change "<<RoundTo(<<stuff>>,0.1)>>" to just "<<stuff>>" to get rid of the rounding. Make sure you get rid of the ",0.1)>>" as well as the "<<RoundTo("
Here are some possibly helpful extra screenshots
