Why are my pdf pages suddenly truncated?
I haven't changed anything since last week.  When I view things, it's ok, but when I print the logs out, it's coming out missing part of the logs.  Nothing has changed with the printer, as far as I know.  We use bluebeam for our pdf software.  The first part of this pic was printed previously.  The last 3 pages was from this morning.
  • One thought is the page size and orientation of your fence report changed, which can happen if you change your default printer that does not support the paper size selected (such as 11x17 being changed to 8.5x11). In report deisgn, the page size will be a double dotted line, make sure it encompasses the full report. You can select  Log Report Properties and check/change the page size there. Also make sure your default printer is the one you want and supports the paper size selected.
  • None of that changed.
    Here's what I've found.
    When I created a new file, everything came out fine.  When I opened a different project and tried appending logs to the original file, they were still messed up.
    In my original pdf, I had some previous logs from the project AND a couple of test reports for some core samples.  These test reports were the last two pages of the file; I was appending to it.  When I rearranged the pages, and moved a gint page to the end of the document, then the addendum logs exported properly.
    So the problem came from having a non-gint pdf page at the end of the document.
    Thoughts?
    Answer Verified By: Jeff Geist
Reply
    Thoughts?
