I've enter information into the well tab, but when I go to OUTPUT and preview my boring log. The well diagram does not show up. I'm not sure how to fix that so it shows up when I've enter information.
I do have a well diagram under the REPORT DESIGN.
Hi Christa, I don't use the gINT standard logs, but took a quick look. That is a "smart" log that shows the well with a conditional output check under Report Variables. It should show if the "Graphics" field in the "Well Construction" table is populated. The "Well Construction" table appears to be a daughter table of the "Well Details" table. Your screen shot of the input does not appear to have the daughter table, so there may have been some edits to your data structure?You should check the actual name of your "Well" table (Well may just be the caption, check under table properties), and change the user report variable table name to match that and it may work.
Hi William,
I am also having this issue with the well graphics not populating when using the gINT standard logs. I have tried using your suggestions but with still no luck. Do you know if there are any other methods that I can try?
Cheers,
Adam
Hi Adam,
William will probably have a much better answer and more knowledge than me, but I had to find a copy of a library that the wells would show up and use that one moving forward since I couldn't figure it out. This library version had the wells as Well Graphic instead of Well Construction. I don't know if this will work for you but here's a few screen shots of what this library has for wells.
In the main report properties:
In the private blocks:
I hope this will work for you, but I'm new at learning the in and outs of gINT so my knowledge is limited.
Thanks!
Christa
