Well Diagram
I've enter information into the well tab, but when I go to OUTPUT and preview my boring log.  The well diagram does not show up.  I'm not sure how to fix that so it shows up when I've enter information.
  • Hi Adam,
    William will probably have a much better answer and more knowledge than me, but I had to find a copy of a library that the wells would show up and use that one moving forward since I couldn't figure it out.  This library version had the wells as Well Graphic instead of Well Construction.  I don't know if this will work for you but here's a few screen shots of what this library has for wells.
    In the main report properties:
    In the private blocks:
    I hope this will work for you, but I'm new at learning the in and outs of gINT so my knowledge is limited.
    Thanks!
    Christa
