I made my SAMPLE TYPE NUMBER into a private block so it will disappear when I don't have any info entered, but also appear when I do. It doesn't seem to be working, I might have the wrong output condition entered in since I'm not familiar with the wording gINT uses.
This is the output condition for the private block:
I do have information entered for the sample type and number:
But in output it is missing:
Try: <<HasData(<<SAMPLE.type>>)>>
That worked ! Thank you!
I've also changed the Private blocks Offset X so it would fill in the space when I don't have anything for the sample type and that seems to not work.
I want the TESTS and U.S.C.S. etc to move and fill in the space that is left from where the sample type would be:
I went into each private block and added the offset x for the sample type:
is this function not correct?
