adding /editing columns in BH template
Hi , I need help with environmental BH template, can I adjust the column where it currently read environmental data to show the SPT N-value, MC, Fines Content(ie.., 3 columns instead of one) ?
  • The answer is yes you can do that, but it is hard for me to give you specific advice since I do not know what your current library looks like or your current template.  If you are using the gINT std US library and data structure or a derivative of it. I would need to know what template it is that you want to modify and how you want it to look.  As a precaution, some of the gint std us templates are dynamic (or smart) logs that change and adapt based on the available data.  These logs are extremely difficult to modify correctly and maintain the smart functionality. If you want to me to help modify the form you need to post a screen shot of the exiting report form that you want to modify (go to report design and then select the report form you want) a picture of how it prints currently and a picture of how you want it to look. I may need addition information depending on what these look like.
Reply
