Missing shear strength values on CPT logs
Hi All,
I am using Datgel in order to create VC/CPT combination logs. For some clay layers, the shear strength is not being calculated or shown in the CPT data table. I am wondering how I can fix this in order to have all shear stregth values plotted.
Thanks in advance!
  • Hi Liadh
    This would be because the layer with empty su is coarse grained.
    If you are using your company's customized gINT Files, my recollection is your colleagues developed a way to override this in the Datgel Formula Tool and calc su.
    regards
    Phil
    Phil Wade
    Datgel
    Bentley Channel Partner and Developer Partner
    E: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
    Get the most out of gINT with Datgel Tools.
    Answer Verified By: Liadh Keogh
