import report template from pdf , logo update all users in the office
Is there a way to import from pdf the borehole data template? If not can you refer me to a tutorial where a new report template is created from the beginning
Is there a setting that allow all users in the office get the logo updated on their computer when one person insert the company logo on the report templates ?
  • If you have a pdf of a blank log form, you could save it as a jpg or png from acrobat and then insert it as a graphic image in a log form. However, this doesn't help you much as you would still need to add all the entities that would populate the form with actual data. If you are going to do that,  you may as well just creat the form from scratch. Further,  because of the raster image, logs will take longer to generate and output files will be much larger.
    Tutorials on log template creation can be found in the wiki on this site.
    If you store your library on a network server, then have all users point to that library, any changes made to the library will be seen by all users. This can be both good and bad.
    I am traveling now but if you want me to expand on any of these quick responses, I should be able to provide more details mid next week. Let me know.
Reply
