editing the heading of template gINT
How do I edit the heading of a borehole template in gINT?
  • Here is a link to a detailed tutorial on how to edit log forms. It and others are in the wiki on this site.
    https://communities.bentley.com/products/geotechnical1/m/mediagallery/272436
    Some things to keep in mind:
    1. I highly recommend that you make a copy of the page you want to modify first and work on the copy. That way if you really screw something up you can still go back to the original
    2. Realize that if the header in the log you want to modify is in a block, modifying the block may modify all logs that use that block. In some cases this may be what you want, in others this can be a real headache to recover from. Make sure you have a backup copy of your library stored safely away in another location.
    3. It helps to understand gINT's support files and how they work. The library file, data template and project file all have specific functions that customize how gINT works for you. There is a video in the wiki that explains the function of each file.
    If you have specific questions on how to modify specific entities you can post them here and somebody can usually answer it or provide guidance. If you post a specific question make sure you include enough information to allow people unfamiliar with your data structure and report designs to offer a solution. Screen shots of the entity properties windows in question and marked up samples of how you would like the log to look go a long way in helping members answer your question rather than the question they think you asked.
Reply
