Hello ,
How do i create line vs depth properties for a new template for well design ? I am not able to copy the line vs depth entity from one template to another
I understand that you wish to copy the properties of an entity in another report. Gint remembers the last entity you edit so if you open the report with the entity you want, click on the entity to open its properties window, then click save without changing anything, gint will remember those properties. Now open the log you want insert into, select the exact same entity to insert and you will note that it is pre populated with the remembered properties. Hope thus helps.
