I am working with an existing log that has a field for the % passing #200 and I have the % passing in the Sieve Readings but can seem to figure out how to write the code to get the value to show up. First time trying to edit an existing log and I sure am missing something. Any ideas?
I post the relevant screenshots
Hi Art,
I am making a couple of massive assumptions.
1. you are using a current standard lab testing module delivered with the current version of gINT
2. you are using the current version of gINT (based on the icon you may have a 10 + year old version)
Try this no guarantees
<<Let(Size = 0.075)>>_<<Format(<<Interpolate(_ <<Union(_ <<SV READINGS.Percent_Finer>>,_ <<HYD READINGS.Percent_Finer>>_ )>>,_ <<Union(_ <<SV READINGS.Reading>>,_ <<HYD READINGS.Particle_Size>>_ )>> = <<Get(Size)>>,A,L_)>>,0)>>
Thinking...
