Can I run more that one Rules Procedure on a line. eg, On Save, run Rule #1 and then run Rule #2, etc.
I have a client that has mixed data in a single table. I Know, I know, but that is the way they set it up and I am just popping my data into their project layout.
If you combine the two sub routines into one, then yea. I'm not sure about running two separate sub routines.
Not an expert at gINT rules but from what I know, you could simply create a separate rule that calls the 2 rules you desire to run in order, then link that rule to the table.
That sounds attractive. First module would call the other. It would basically be a modMain. Ill give it a try.
