Hi all,
I am using Datgel with gINT to create CPT logs. When I create the logs, a black triangle appears with the cone resistance. As these are offshore CPTs I wish to remove this trainagle. Is this possible?
Thank you in advance.
Hi Liadh
Check your settings on the Symbology tables for Cone Resistance, refer to https://docs.datgel.com/cpt-tool/4.0.0/user-guide/reports/report-symbology
regards
Phil Wade
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
