I'm creating a "text vs depth" entity to portray the undrained shear strength value. I'd like to format the values to "align right" so that there is no space (highlighted in yellow) as shown in the screenshot below.
I've tried the text expression to be "<<R>>c<<SUB>>u<<SUB>><<LAB_SOIL_TRIAXIAL_TOTAL.Undrained_Shear_Strength>><<R>>" with the <<R>> at the start and end of the expression, but it does not seem to be working.
Can anyone please advise? Much appreciated.
Thank you.
To update:
I've figured how to justify the text to the right. However, the discrete graphic does not seem to be at the same alignment when the value is 3 digits. May I know is there any way to have the solid circle on the same alignment? I'm currently using this setting in the text vs depth properties.
This is probably due to the override horizontal alignment being set at Center instead of Right or Left for the graphic
Hi Allan,
Thanks for the tip! Yes, I've managed to resolved it. Thank you!
