Subdividing columns in gINT
How to I subdivide a column to include text and plot entities?
  • It is not clear to me exactly what you are asking but the following may or may not help.
    1. If you are asking how to create multiple columns with a single header as in the example you posted. I typically create this set up as individual columns with no headers for the data. I then creat the header to look as I want it using text and line entities. Rather than using a colum, you can use just text vs depth entities that do not have header info.
    2. If you are asking how to include more information in each of the columns of your example you can edit the text expression on the column to add the desired info. It can be aligned using tabs or left right center justification. You can also add I fo using the second text spec tab of the column entity.  Graphics can be added using the descrete graphics tab of the column entity.
    3. If you want to subdivide the circled columns in your example this can be done using tabs in the text expresion as stated above or by adding additional columns and repositioning and resizing the existing columns. You will have to manually adjust the header
    If you can provide more specific details on what you are trying to do, I can provide more specific advise.
