Is it possible to output or export data from multiple gINT tables to Excel so each table is exported into distinct Excel worksheet? I`m able to setup excel output but I can`t find any solution to create excel table with more than one worksheet. Any advice would be much appreciated.
Thank you all for your replies. I forgot to mention that the export need to be with excel worksheet named in different way than in gINT. I will use corespondence file pointed out by szang.
