Hello - I'm doing a plot fill for CPT data on fence diagrams and it is include black horizontal lines. It does not give me a choice for no horizontal lines and when I output to PDF it looks back because Adobe is turning thin black lines into thick ones. I don't want any horizontal lines. Is there a way to get rid of the horizontal lines? Snip below.
Hi Monique,
A couple of setting may help. Under the Plot Fill tab in the plot vs depth entity check consolidate adjacent like sections. This should only put a line at each color change. In addition to checking that if you also don't want a line at each unique color change, also in the plot fill tab in the linetype from box put in -1 This forces the line type to be "None"
Thank you Kirk. Using -1 worked perfectly.
