I have a log in gINT where the depth of the layer spans multiple pages. It is my understanding that GINT should automatically look and see if the layer description spans 2 pages and repeat the description on the second page. However my gINT log is not doing this and I do not know why. I have the settings for my material description column pasted below. My layer is set to have a depth from 1.9 to 50 ft which should put it on the first and second page however it only prints on the first page while the second page is blank.
What do I need to do to make these descriptions that span multiple pages repeat on each page?
(I Assume the Relevant) Material Column Description Properties:
Units Depth Inputs:
^This is the library table referenced in the description properties. As you can see the depth of rock is referenced here.
Resulting Boring Logs
^As you can see no description on page two. How to I get one to appear here?
Hi Tanner,
While I can't determine everything from the screenshots. I think it is likely your bottom Depth expression in not referencing the right <<Table.Field>> names
Try <<Lithology Rock.Bottom>> in the bottom depth expression in your first screen shot instead of Rock.Bottom
Answer Verified By: Tanner Avery
That fixed my problem thank you!
