Has anyone seen this error? I copied the file to a different computer and multiple different locations, and it still says another user is in it, which is impossible because of the different location where I copied the file. I also cannot repair it.
Yeah - no - tried step 2 didn't work- same error. Can't do Step 3 and 4. Not having fun... Thank you for all your help though! Hopefully this thread might be useful to someone else. I hope this forum doesn't go away when gINT support phases out. It is a great resource! Not ready to go to OpenGround for a few years yet. Too much infrastructure to rebuild.
Uh Oh. Is Open Ground not going to be able to use the gINT files that you are using now???
Hi Monique, it may not be the issue, but I would suggest re-installing your MS Access database engine. I have had a few weird problems that were solved by that, besides the classic "can't open database created with previous version"
Monique, try repairing Access database engine 2010 through your control panel.
Thank you. That was one of the first things I tried, although it is usually associated with a different error.
