How do I make the program to display all input and output values either in metric or imperial?
ie., All inputs in Metric and all output in imperial or vice versa
Right now all my inputs and outputs all metric units
There is a mandatory field in the point table called HoleDeph. This field controls the depths of column displays. All entities have an option in them to plot to hole depth or bottom of page. It is located in various places in the entity and some entities have it in 2 places. For example, The scale entity in the example in 4 above has one in the main tab which is set to bottom of page (see picture above). I could be set to hole depth. This entity also has a control on the column lines tab which controls the lines on the side of the column. A text entity will only have a control on the column lines tab. A graph entity might have more than one control, I forget. It appears as if the HoleDepth field for the boring in your example is set to 1m even though the hole goes much deeper than 1 meter. It also appears that your log form is set to terminate column lines, scales, etc. at the hole depth for the fields shown. You can fix this by allowing the entities to go to the bottom of the page or by correcting the HoleDepth Field in the data. To get the ticks to scale correctly if you are going from meters to feet the scale factor should be 0.3048. You will have to adjust the tick and number spacing on the tick and number tabs so that it is not all crammed together.
