Hi there I am trying to only show the data points within defined axis extents however gINT still plots the outlier datapoints on the axis edge. Is there any way to turn this setting off so that only data points within the axis extents are plotted on the graph?
In the main tab of a plot vs depth entity there is an overflow property that controls what you want to do with values that exceed your data axis range. Choose the one that does what you want.
