I am noticing that in some boring logs (for the same project), the WT symbol is not showing.
Please see attached.
Thanks.PDF
If you are using the same report template, and the data is in the same "AD" depth field and is not showing, check to make sure that there is no text iin the field, such as "7m" vs "7". This needs to be a numerical value with no text to plot
Thans William.
There are only numbers, such as "7".
Is the data in the same "AD" row, or is it in EOD or ATD row? There are usually different entities with different symbols for the type of reading, make sure those entities exist in you report design
ok, I got it.
I am not sure i i need to start another thread. See the file attached, there are 2 lines of AD, 2 of ATD and 2 of EOD. There is a duplicate of each.
Is there any way to eliminate the duplicates?PDF
I'm not sure about the duplicates, but from your first post it looks like AD readings are plotting ok? Try changing the reading type to AD and see if it plots like the other did. Alos, I am assuming you are using the same log report for both
The way how it actually worked was by using EOD (End of Drilling) cell. It plots ok.
There is something weird with the AD. I remember from other projects, I had used the EOD cell.
About the duplicates, it is just annoying. I have been seeing the duplicates in the last years, so I was just wondering how to eliminate them.
Thanks again.
